dana 60 yoke vs dana70 yoke
- lightning4x4
- City: cave junction
just put dana 70s in my truck apperantly rear is an newer model from front (68vs 78) the yoke on the rear is massive my question is there are difference between the dana 60 yoke and the dana 70 yoke ? both from what I can tell from research have 29 splines . not looking forward to having driveline work done again .thanks
Re: dana 60 yoke vs dana70 yoke
Ya, bigger trucks have bigger metal to handle bigger weight.
The transfer case is where the bigger/smaller yokes are interchangeable.
- lightning4x4
ok thank you not interchangeable , drive line modification it is .
Dana 60 and 70 will interchange yokes BUT 68 will have coarse splines and 78 will have the fine 29 spline.Many size yokes are available for your 29 spline diff.
91w350 CTD
93w250 CTD
91w350 CTD
93w250 CTD
Doug,digdoug wrote:Dana 60 and 70 will interchange yokes BUT 68 will have coarse splines and 78 will have the fine 29 spline.Many size yokes are available for your 29 spline diff.
What is the cut off year for the coarse spline yokes for the Dana axles?
- lightning4x4
good news my drive line guy says there is a conversion u-joint for that application
For the most part, 68 is the cut-off, though in very few cases it can go to 70.Hobcobble wrote:Doug,digdoug wrote:Dana 60 and 70 will interchange yokes BUT 68 will have coarse splines and 78 will have the fine 29 spline.Many size yokes are available for your 29 spline diff.
91w350 CTD
93w250 CTD
91w350 CTD
93w250 CTD
Thanks for the ex spline ationdigdoug wrote: For the most part, 68 is the cut-off, though in very few cases it can go to 70.
91w350 CTD
93w250 CTD
91w350 CTD
93w250 CTD
