Power Steering kit?
franktiregod
City: Covington
Power Steering kit?
Post by franktiregod »
I searched this and about went blind reading all the posts. Some of them conflicted each other within the same thread. :lol:
So did CPP ever make the kit or not? I went to their site and could not find anything. If they did make it, who used it and what were your thoughts on it?
I would like to add power steering to my truck because backing up to a trailer is torture.
6-16-1986 12-5-2008
powerwagon54
City: Washougal
Re: Power Steering kit?
Post by powerwagon54 »
pm sent
franktiregod
City: Covington
powerwagon54 wrote:pm sent
Got it. Thanks!!
6-16-1986 12-5-2008
my5thmopar
City: Columbia
Post by my5thmopar »
Yes they make one but, you have to call. They sell the steering box and you get the common stuff. I have one on my 64 with a /6 and it works great. I have the power assist on my 70 D200 (But it is a 383) and it doesn't turn as easy as the CPP.
Crewcabstripper
City: Dude
State: PA
Post by Crewcabstripper »
What all options are there for a power steering swap? Saw some mention CPP, Toyota box and ford box installs.
slick
City: Tucson/AZ
Post by slick »
Curls,forearm curls, then maybe some tricep extensions.. :Thumbsup
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
Conrad
City: Austin
Post by Conrad »
I'm actually liking the manual steering - I've gotten used to not moving the steering at a standstill and it's fairly easy to turn (if not overly vague) otherwise. I just wish I had a faster ratio. As others have posted here, having a 20:1 option would be much improved. OK, maybe the steering isn't that great... ha :lol:
lightning4x4
City: cave junction
Post by lightning4x4 »
I bought one of these kits for my 70 w200 383 ,you have to call to get it not on the website. i read a lot on this forum first. had to get pump at store locally , order pump brackets online , it uses Toyota lines or that's what the box said, all in all I like it .like some of the others I cant turn wheel at dead stop ,but I couldn't with the manual box anyway with 36's
Conrad
City: Austin
Post by Conrad »
I'm interested to know whether you updated your caster when you installed the power steering.
For me, there are only two benefits over what I have now: a faster steering ratio and increased caster for improved directional control. Good example I had today, I had to back-and-forth 4 times to get out of a spot at the local Top Notch burger stand. On the positive side, it gave all the other MoPar guys a good chuckle as they watched me fighting the steering. :lol:
lightning4x4
City: cave junction
I fixed the caster when I put lift springs on the truck flipping the springs around gave me what I needed. of course now that im changing axles again ill have to recheck it .the faster ratio defiantly helped
MadMC63
City: Rome
Post by MadMC63 »
1971 Dodge D100
RH62
Post by RH62 »
I'll wait till they figure out why some don't turn at stand still position. I was excited about this kit but now not as much
johnah
City: Pompano beach
Post by johnah »
After king pins, new bushings (spring and sway) then yet another alignment I'm go to go. Steering at stand still is about 90% corrected everything else about the steering is spot on. Just put 2000 plus miles cross country trip with no problem and no excess tire wear. :clap I installed the CPP kit June of 2015 I think it was the 3 or four kit they put together.
https://www.youtube.com/watch?v=6pdQ79OxUFc
https://www.youtube.com/watch?v=su8J-ddN-_4
