I have seen Cummins swap threads here where they either omitted the fan, or cut the firewall to make it fit. So I was thinking, What if a guy moved the cab back to create enuff room, then stretched the fenders and the cowl top? So my question is, how much room is needed if I used the stock fan, plus intercooler and AC condensor? Is 3" enuff? Once I know much extra room is needed, then I will do some scale drawings to see what it would look like with a stretched front end. I am converting a crew cab shortbox to a long box, so I will be grafting the 2 frames together. That gives me an opportunity to make the frame longer to move the cab back.
Thanks, Joel
Stretching engine compartment to fit a Cummins?
1968 D200 4 door 318 auto power steering
1966 D300 slanty 4 speed flatbed with Schwartz dump
1968 D200 crew cab project to become a longbed cummins dually
- slick
- City: Tucson/AZ
- State: AZ
Re: Stretching engine compartment to fit a Cummins?
Check this build thread out. viewtopic.php?f=34&t=24308&hilit=cummin ... b&start=60
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
1961 Dodge D100
1964 Dodge Polara
Very interesting, thanks. Those lengthened front fenders actually look pretty good.
