Hi All,
I am trying to find a shop in the San Diego area. Anyone know of a decent one?
Thanks!
James Veltri
San Marcos, Ca
Anyone know of a shop to boil out a gas tank in San Diego?
- City: San Marcos
- my5thmopar
- City: Columbia
Re: Anyone know of a shop to boil out a gas tank in San Dieg
Any radiator repair shop or engine machine shop could do it. Here is how you do it yourself. Get a long heavy logging chain (my preference) or gravel or nuts/bolts and put it in the tank. Place it on the grass and shake shake, turn over shake some more. Blow out the dust and debris then rinse it out with acetone or gas. If your going to coat it with Red-Kote or similar, then follow their directions. Have fun and welcome! Craig
1964 D100 Utiline
2019 Ram Classic
viewtopic.php?f=34&t=40251
2019 Ram Classic
- City: germany
Hello from germany.
I made it many times with lemon acid powder from the supermarket and hot water.
Big tank needs many packages.
Works over one day.
Removes also rust.
At the clear alcohol . It takes away the rest of the water.
I hope you understand my bad english.
Rene
Works over one day.
Removes also rust.
Rene
- City: San Marcos
Hello Craig and Rene,
Thanks for the advice I will look into your suggestions. I have to deal with the floor pans at the same time. Priorities!
It is a family heirloom and I wa t to keep it going and am grateful for this site.
Cheers!
James
Cheers!
James
Easier to just buy a nice used tank from Bud or myself.
- gyman98
- City: Saskatchewan
After you put some hex nuts in it ratchet strap it to the rear wheel of a truck with it jacked off the ground. Put it in gear and let it slowly spin
