Gas bubbling in clear filter
oldfrogdiving
City: melbourne
Post by oldfrogdiving »
Ok gentlemen here is a slight issue I have just uncovered in my 66 D200 slant 6 carter single BBL, Np 435, I have been driving all morning stop and go traffic, no problems no overheating, when I got home I was doing a routine oil check (slightly below full) and I noticed the clear fuel filter bubbling. I checked my water level its topped off and not low, no water seepage from pump, belt tight, fan Aok, I'm running my stock oil bath type cleaner. I have never noted this, the truck is running fine and its about 85 degrees here today its winter you know? I have never noticed this before but cant imagine its normal, I fired it up and checked for water circulation which has never been high volume. I do have a replacement water pump. As usual your thoughts appreciated.
Thanks
Frog
66 D200 225 uti (ex mil, gone but not forgotten)
71 W200 318 4spd limited slip 67k
89 F250 7.3 idi 61k
87 Dodge Raider 91k
96 F350 4x4 PSD 109K
Re: Gas bubbling in clear filter
Engine heat boiling the gas. No problem, unless it boils completely into vapor, then u have "vapor lock".
oldfrogdiving
City: melbourne
Thanks that's what I figured.
89 F250 7.3 idi 61k
87 Dodge Raider 91k
Throw some Beano in the tank and it will clear right up. :lol: :joker
