wiper are removal
- dcgronlund
- City: portsmouth
- State: VA
wiper are removal
I've done a search on every forum I could find and google. I cant find good advice on how to remove the arm from the splines. I know about the tab, I think mine is just really stuck. does anyone here know a good way to remove stuck wiper arms without ruining them. mine are really nice and I would like to save them. thanks.
David Gronlund
1969 Dodge D200 Custom
1999 Ford Ranger
2014 Dodge Durango
1999 Ford Ranger
2014 Dodge Durango
Re: wiper are removal
As you've already probably guessed, it is most likely RUSTED on. After you've unscrewed the bolt, try a HEAT gun... Tap with a wood or rubber hammer while prying UP with a big prybar or screwdriver. This is JUST A SUGGESTION... So... be careful.
- dcgronlund
- City: portsmouth
- State: VA
mine doesn't have a bolt/nut. the arm is smooth over the crank splines. I guess i'll keep messing with it.
David Gronlund
1999 Ford Ranger
2014 Dodge Durango
1999 Ford Ranger
2014 Dodge Durango
Lift up on the wiper arm. With it up in the air push down on the arm , it's
Spring loaded. While pushing down take a large flat blade screwdriver on opposite side,barely catch the edge gently rock it should pop off.
- powerwagon54
- City: Washougal
if yours does not have a nut, they are not factory arms. You have an adaptor on the wiper pivot that the arm is sliding down on. They can be tight.
- dcgronlund
- City: portsmouth
- State: VA
awesome thanks. ill try it tomorrow.GMAN69 wrote:Lift up on the wiper arm. With it up in the air push down on the arm , it's
David Gronlund
1999 Ford Ranger
2014 Dodge Durango
1999 Ford Ranger
2014 Dodge Durango
