Replacing stock axles with newer
- City: Fairbanks
- State: AK
Hi, found a deal on a 77 Chevy Crewcab long bed 3/4 Ton truck frame. SRW 4X4 GM 14 bolt rear axle. 8X6.5 Lug pattern, rolling chasis. Was wondering if this would be an easy swap into my 1970 Dodge W200. This would give me power steering and disc brakes up front.
1970 W200 Utiline, 318, 4spd, "Tater", Mater's unkown cousin
Re: Replacing stock axles with newer
Which side is the front diff on? Does it line up with your t-case?
77 GM 4x4 trucks of that vintage use Pass side drop like Dodge.PwrWgnDrvr wrote:Which side is the front diff on? Does it line up with your t-case?
- City: Fairbanks
- State: AK
Correct, GMC and Dodge are passenger drop.
This chasis has the steering column, brake booster, power steering unit, drive shafts.
How difficult or easy would this be?
