Hi everybody. Have a D200 camper special (383 + automatic) with side gas tanks and regular tank in cab. Fuel lines appear to be some sort of clear plastic that all hook up to a three way block with a single line to fuel pump. Would like to replace lines/clean block and run all three tanks but not sure about "usual" operation. No word in manual about how they're supposed to work. Any help or advice greatly appreciated.
Thanks!
Camper special fuel tanks and line
Re: Camper special fuel tanks and line
Plastic lines to me scream Not original. Easy to figure out valve operation by just figuring out the path of fuel flow when in certain position's.
The "block" is a valve that selects between the tanks. Usually floor mounted below the seat, frozen in one position and the handle broken off.
