Sloppy steering
fireguyfire
City: Cochrane
Sloppy steering
Post by fireguyfire »
Playing around with the 69 today and noticed how much slop there is in the steering; a lot!
Had my son turn the wheel back and forth until the wheels turned while I was underneath and it looks like all of the play is in the gearbox, not the steering linkage. We will probably replace the tie rod ends anyway this winter, but how do you go about tightening up the slop in a gearbox? Does it have adjustments, or does it need a rebuild or replacement to get it tight?
Johninky
City: elkton
State: KY
Re: Sloppy steering
Post by Johninky »
Does have an adjustment screw on the engine side of the box. Have to loosen the lock nut and then use a screwdriver. Been told when making the adjustment the wheels need to be off the ground. Also been told you can adjust the box too much which is bad because you can't "take out" adjustment. So, just small adjustments to start and then test the steering.
Box is probably worn out and the adjustment won't accomplish anything but what the hey, nothing ventured, nothing gained.
JimE
City: Glendale,
Re: Sloppy steering
Post by JimE »
To do this adjustment correctly you must remove the idler arm from the steering gear. Jim
03 Hemi Ram 2500
johnah
City: Pompano beach
Re: Sloppy steering
Post by johnah »
If you can't get the slop out by adjusting it I have a rebuilt manual box with about 1500 miles on it for sale. Replaced it with a power steering kit from CPP. If you have the $$ for the power kit that's the way to go. My is working great.
67raddish
City: pittsburgh
State: PA
Re: Sloppy steering
Post by 67raddish »
YOU WOULDNT HAPPEN TO HAVE ANY INFO ON THE P/S PARTS FROM THE COMPANY YOU MENTIONED? WOULD YOU?
Re: Sloppy steering
67raddish wrote:YOU WOULDNT HAPPEN TO HAVE ANY INFO ON THE P/S PARTS FROM THE COMPANY YOU MENTIONED? WOULD YOU?
http://**NOT ALLOWED**/
oops! I forgot. :pale
Try this: http://www.classicperform.com/
67raddish
City: pittsburgh
State: PA
Re: Sloppy steering
Post by 67raddish »
I guessed that there was stuff like that out there but I just didn't know where to look. Thank you very much this will be a big help. I just picked up a 67 d100 in pretty good shape. needs mostly cosmetics more so interior then exterior. But a few mods to make it a little more user-friendly would be nice. Again thank you
Re: Sloppy steering
67raddish wrote:I guessed that there was stuff like that out there but I just didn't know where to look. Thank you very much this will be a big help. I just picked up a 67 d100 in pretty good shape. needs mostly cosmetics more so interior then exterior. But a few mods to make it a little more user-friendly would be nice. Again thank you
This thread will bring you up to date on this conversion :Thumbsup
viewtopic.php?f=20&t=34169&hilit=cpp
67raddish
City: pittsburgh
State: PA
Re: Sloppy steering
Post by 67raddish »
tons of great info on that link. im going to have to see how much just the box costs. trucking with brackets the pump and hoses somebody was starting to do the conversion just never got the box. I see it says that a Toyota parts for a ford box will make due. any idea of the year and model on those boxes?
Re: Sloppy steering
67raddish wrote:tons of great info on that link. im going to have to see how much just the box costs. trucking with brackets the pump and hoses somebody was starting to do the conversion just never got the box. I see it says that a Toyota parts for a ford box will make due. any idea of the year and model on those boxes?
U need to go read this, all the way to the bottom:
viewtopic.php?f=13&t=40605
Re: Sloppy steering
:lol: :lol:
Whoops.... Here we go again... :joker
slick
City: Tucson/AZ
Re: Sloppy steering
Post by slick »
Or just send it to bud thorpe and have him rebuild it. He did mine in my crewcab and that made a huge difference..
1963 Crewcab
1965 Crewcab
1968 D-100 Longbed
1948 Dodge Panel Truck
1964 Dodge Polara
1957 Shasta
slick
City: Tucson/AZ
Re: Sloppy steering
Post by slick »
Or just send it to bud thorpe (powerwagon54) and have him rebuild it. He did mine in my crewcab and that made a huge difference..
1963 Crewcab
1965 Crewcab
1968 D-100 Longbed
1964 Dodge Polara
1957 Shasta
