LU-2 winch shift handle
I've got an LU-2 winch on a 1967 w200 on which the handle that engages the winch is broken off and missing. I think that I can make one if II knew what it was suppose to look like. Does anyone have a diagram with demensions ? Thanks, Jon
Re: LU-2 winch shift handle
Jon,
Start here: http://www.bradenwinch.com/pdf/LIT2028_ ... 4-2002.pdf
You can contact Braden and it is possible they may still have a handle for your winch.
Good luck
Good luck
1970 W200
318, NP 445
Factory LU-2 winch
A/C, HD Gauges
318, NP 445
Factory LU-2 winch
A/C, HD Gauges
Braden does indeed have the part but the handle assembly goes for over three hundred dollars. A little steep in my opinion.
On the off chance.... check with Dave Cirillo....allsupj wrote:Braden does indeed have the part but the handle assembly goes for over three hundred dollars. A little steep in my opinion.
http://www.jobrated.com/06_winch_pto_parts.html
