heat riser
heat riser
This might sound like a dumb question. I have a 65 D-100 with a 318 Poly. The heat riser will only move if I move it by hand. what position should it be in. I can pull it up toward the fire wall or it will go all the way down. I want it to stay open all of the time as I live in a warm weather area.
Re: heat riser
If the heat control spring is missing then you should remove it or fix it. The valve flapper should be open to allow the exhaust to pass through unhindered.
Re: heat riser
What position is open with the heat riser. Is the riser all the way up to open or down?
- riffraff
- City: Newport Beach
Re: heat riser
Hopefully this helps:rd200 wrote:What position is open with the heat riser. Is the riser all the way up to open or down?
I just replaced my passenger's side manifold that had the valve, with a driver's side non-valved manifold. 1969 W100 w/383
viewtopic.php?f=19&t=36208
Tom
1969 W100 383/435
1969 W100 383/435
