Converting small block truck to big block
- tragic59
I have a 67 318/727 D-200. I want it to be a 67 440/727 D-200.
I found a 68 D-200 big block truck in a wrecking yard, and I'm curious what I need to take off of it to make the conversion. It's motor is gone, but I already have the 440 and tranny in the garage anyways.
Do I need the motor mounts off the frame?
Tranny mount cross member?
Shifter cables?
I figure I need the drive shaft, right?
Anything else I'm forgetting that will make my life easier when the time comes for the swap???
Thanks.
Shifter cables?
Thanks.
- Jeffc
You will need the big block raditor, it sets farther foward than the small block one......
engine mounts on the engine side, the bb ones make it fit very nice, smb ones can be made to work but don't fit right and may need some work to fit......no change to frame mount side...
Drive shaft should swap as long as splines line up in the tail shaft.....
cable shift stuff will all swap except arm on trans
and kickdown arm as John said...
- dusty
- City: applegate oregon
radiator swap
i made the sb radiator work by spacing it forward and switching outlet side,depending on witch water pump housing you have
My 68 power wagon has a 383 in it from a 2wd truck. It was a bolt in swap right down to the oil pan. You will need B series trans and converter, trans lenght and crossmember identical, a good triple core radiator, truck specific big block exhaust manifolds and headpipes, throttle linkage and you have it all. Big blocks RULE!
What is the difference in the underhood wiring between the small and big block V-8's? I don't know where to find the big block wiring.... We are currently doing this same swap, but I had not thought about the wiring being different..... so info please.
1963 D300 flatbed
1964 D100 stepside
1967 W200 longbed
1969 W200 crewcab shortbed
1971 D100 shortbed (current project)
1974 Cuda
2002 Dakota Quad
1964 D100 stepside
1967 W200 longbed
1974 Cuda
2002 Dakota Quad
My truck is a 1971 and the 440 is a 1970....the distributor is up front on the 440 and I believe it was in the rear of the 318. So are you guys thinking that some of the wiring will just not reach? Or are other problems lurking in the shadows? Thanks for the reply.......
1963 D300 flatbed
1964 D100 stepside
1967 W200 longbed
1974 Cuda
2002 Dakota Quad
1964 D100 stepside
1967 W200 longbed
1974 Cuda
2002 Dakota Quad
