shifting rods on 69 3 speed column shift
DB69
City: La Porte
Post by DB69 »
I have a problem with the rods sticking when the truck is warm or has been run awhile, it usually gets stuck in 2nd gear and I have to unstick the rods so that I can shift . I have lubricated them but the problem still persists. what else could be wrong with it? the truck only has 13,360 miles on it.
Also does NAPA still sell the master cylinder for this truck?
Thanks to all for help and advice :salut
DB69 :usa
TommyDodge
1997 Dodge Ram 1500 Club cab 3rd owner 86,330 miles
I don't drive a Ram-I drive a Dodge Ram
Dodge Brothers Detroit USA,
In Memory of Molly and Missy, My Beagle Girls
A440cuda1
City: Cheney
Post by A440cuda1 »
don't quite know where to start with the rod issue...haven't had a column shiter truck in a few years....but yes...the master is still available from napa....but you might get a better price at RockAuto.com
1962 D100 Short bed project
1963 D200 Long bed
1970 D200 Long bed
Many other old rigs, not sweptline related.
wideblock
City: las cruces nm
State: NM
Post by wideblock »
DB, under the hood, where the shifter crap is on top of the column. there is a U shaped bracket that holds both shift levers, at the bottom of that bracket (the side furthest from the fire wall) there is supposed to be a wave washer between the bracket and the bottom of the shift arms. these wear out and break pretty easy, thus leaving more slack in the arms then was intended. this lets the selector pin go between the shift arms, rather then engaging in the slot where it belongs. check the slack on your arms at the column. if you can slide them apart, or move the whole assembly up and down the shifter shaft at all then you got too much slack. i put a small stack of washers on mine to remove the slack and keep the arms togather like they belong. worked like a champ. :Thumbsup
