can one of you two , please enlighten me on your trick to shine up primer , I have some ideas if one of you can hepl me out on this
thanks
8)
Robin, or Clint
Robin, or Clint
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
BECAUSE OF THE BRAVE
67 w100 318 3spd
LAND OF THE FREE
does it stay for just a while , or is it a weekly deal ? I don't mind waxing , as I do it already on my other trucks , I'am thinking :roll: of painting my truck a flat black with a pin stripe right down the sweptline , the desert tqurise( sp)
8)
8)
cowboy Alvin Tx
67 w100 318 3spd
LAND OF THE FREE
67 w100 318 3spd
LAND OF THE FREE
- oneowner71
- City: Fort Worth, TX
If I had to guess, Robin and I arrived at the shiny primer in much the same way.. sanding. I wet sanded mine after applying with 1000 grit just to see how much of a shine you could get out of Krylon primer... but it would be much simpler with gloss paint, just an even looking coverage is a little more difficult to obtain when using spray can gloss. If you're painting with the intent of it being the final coat and want it shiny, definately use gloss... i was playing around with styling schemes.
Thanks, Clint
1971 D-100, 318 3-spd
1970 Dude, 383 / A727
1971 Plymouth Satellite,
2002 Dodge Ram 1500 Quadcab
- wideblock
- City: las cruces nm
- State: NM
hey dave, if you want a good rattle can gloss black, but that appliance epoxy. made by rustoleum, i use it at work all the time. very forgiving, has a nice fan spray tip instead of the round spray like krylon, its self leveling so it doesnt orange peel, and its twice a tough as regular paint. just takes a bit longer to cure, so check your weather before spraying.
shiny primer
Cowboy,
I didn't use can primer, I mixed it and sprayed in on, the shinie part came from just like Clint said, Wet sanding with at least the 1000 grit, I was doing body dings and sanding with 1500 grit, if you want the primer look, don't forget to seal it, so it won't rust, actually the best thing would be to primer then spray with a paint gun, clear coat, it would then last as long as a paint.
- oneowner71
- wideblock
- State: NM
thats a 50's and 60's trick there clint. flat black primer, some semi gloss clear coat, and you get the suede black that was popular for a while. good suggestion robin, and good schooling on these young ones!!! :D :D
