need weight
need weight
I am sure it's been brought up
but how much does a 66-68 3/4 ton pickup weigh
need pretty close weight for shipping
The rate is the cheap one,
just need to know if he can haul all 3
or if it will be just 2
may have to drag one to the scale to find out
if no one knows
even the weight of a long box 1/2 ton would be close enough
if no one knows
- Jeffc
My 66D100 poly 4 speed longwide bed tipped at a little over 4300#
weight
Title weight with /6 3600 on 1970 D100, put in 440/727 and she went across the scales at 3850
- wideblock
- City: las cruces nm
- State: NM
my 66 went across the scales at the local waste yard at 4250 with the trailer you built in tow. figure the trailer is about 600 pounds, and robins quote is pretty close. never been thru the scales empty with no trailer. but the crew went across empty, no trailer, at 4628. (the blue one)
- MowagW200
- City: 5417
- Location: Untersiggenthal and Steg im Toesstal, Switzerland
My Mowag W200 (a late '63 Dodge W200 with a custom body - pls look at the members ride section w- series and 1964) is 6330 lbs. On both axles the weight is about 50 %. The weight is with me, a spare wheel, and a normal tool set. The weight of a wheel (split rim with 8.25 - 16) is 140 lbs. And there is a Braden winch on the front bumber.
Dieter
Mowag W200, 318 A, 200 HP, 4.88 axle, NP 420 4 speed - 2281199520 (on the frame)
1956 Chrysler New Yorker Newport, 354 HEMI, 2 speed powerflite, N56L3495
There is 3 of them to move about 1400 miles,
so towing is too much in time and distance.
Have towed one from California to here about 925 miles one way
and one from Texas, near Dallas to here,.
but yes towing works and I have built a good tow bar for it
for got the one towed from Neveda about 400 miles one way
made me think of the old Beach Boys song
I get around, but now I'm old and round
Trey,
These 3 are in Oregon, and Washington.
No more in Texas, and not for a long time, unless it's El Paso,
that's the same distance as Phoenix.
Will still have 1 in N Idaho and 2 in NE Washington, then
I think I'll have all mine in the same general area
