door glass
- Jeffc
You have to remove the door top, 4 bolts (2 each end)
remove the lower wing divider bolt (though lower
hinge panel), then you have to find the 2 screws
in the wing rubber (one under the wing between the
divider and wing post, one in the upper corner
(if it is a 61 or 62== the early
ones have 3 that come though from the outside of
the frame that hold the wing to frame))
When installing and removing the door top it helps
to have the window halfway rolled down.
