Has anybody gone through the trouble of having a sweptline-era steering wheel restored? I'm working on a '62 D-400, and the steering wheel is pretty tired looking. I've not even begun to shop around for who might be able to do the work, but I know enough about it to know I don't think I'll try to tackle it myself. There are just too many contours. I really like it, though.
Thanks much everybody!
Dan
steering wheel restoration
- WD
- City: Rosemark
File any cracks in the plastic down to the metal, using a triangular file. Fill the grooves and low spots with flexible bumper patch, you can get it at NAPA. Sand to 320 grit, hit it with a good rattlecan etching primer. Sand the primer to 400 grit. Spray with high build rattlecan primer. Spray with white or black rattlecan appliance epoxy. 2 or 3 coats should more than do the trick. Good project to kill a couple weekends.
-WD
-WD
steering wheels
Thanks Jim and WD. I'm familiar with the POR kits for steering wheels, but have never done one myself. Maybe it's time I learned. My only concern was that there are a lot of ridges on the Dodge steering wheels of this vintage, and I wasn't sure if a kit would do a good job. I guess I won't know until a try. Thanks again and take care.
Dan (dxdan)
Dan (dxdan)
sterring wheel
Gary's Sterring wheel restoration is very good. They are currently doing my 64 sweptline. Eastwood has a kit to do it yourself if you are interested.
