Rusty box
Rusty box
So I am restoring my '66 and had what I thought a PERFECT bed. Not hardly a ding in the entire box (except the tailgate) or a speck of rust. Then I removed the tool/utility box that was bolted to the front of the bed and there it was...RUST where the vertical front panel jouns the bed most the way across and in about 3". The vertical panel is no problem to cut out and butt weld in a new panel, but what do I do for the floor??
- Jeffc
how rusty is it, holes, big pits, ect....?
A lot of work to just replace one part of the center
of the bed with a cut in, but could be done with a
parts truck......
I know that JCWhitney has repops of bed the center sections,
don't know if they are for are "our" trucks since I haven't needed one....
parts truck......
- scoutski
I had a similar problem with the bed I used to make my Swept trailer. Just grind out the rusted area and use somthing like POR15 to inhibit advancement of the oxidation. Then I used a piece of 4"x2" base angle that can be had from any steel building supplier. Weld the base angle into the front of the bed. The 4" side should cover the 3" rusted out area. This leaves the gaps in the bottom of the bed to drain it. I also welded a piece of base angle to the front side of the bed to give it added strength.
Bill
Bill
Scoutski
68 W200 PW (sold to Big-J)with a 76 200 por nada
77 Scout II Original
74 Scout II SSII clone
69 800 Gold Key
65 80-800 parts
68 1300 PU with venerable 266
76 Scout II XLC parts truck
55 R110 PU parts???
69 800 Gold Key
65 80-800 parts
55 R110 PU parts???
