I was going to use a steering column out of an 83' ramcharger, it has tilt, and the column is loose at the intersection of the upper and lower half, were it tilts, and i was wondering if anybody has ever been able tighten one of these, i know a chevrolet tilt has three screws internally that you can tighten and i was wondering if it might be like that, yes i know that is a mopar column not a chevy, any help will be apreciated,
jarrod1964
steering column
- City: spencer
- State: IN
- Location: North east corner of Greene county, south central Indiana, just west of Bloomington
- City: B.C.
Re: steering column
Actually I think the tilt columns may have been built by Chevy. I'm pretty sure the 78-80 trucks tilt columns were made by GM.
Sheldon
Sheldon
- Trailmaster
- City: Ellicott
Re: steering column
Saginaw tilt columns were used by GM, Chrysler, and AMC from the 70s to ???. There are a few minor diferences between the column, mostly in cosmetics, but they are so similar that you can even interchange the ignition lock cylinder between the three.
75 Duster 225/904/PS
