speaker in grill
- City: Charleston
- State: WV
speaker in grill
What held the original speaker in place? Any recommendations? Bob
Re: speaker in grill
I cant tell, but I got a 5" speaker and used 4 Carriage bolts through the grates. Doesnt look bad.
- nfury8
- City: KC, MO
Welcome!
What year?
Not sure about the earlier trucks, but the 69-71 trucks had a plate the speaker screwed to.
Then the plate bolted to the dash with 2 bolts hidden under the defrost vents.
Here is the plate loose, and how I modified one to hold a pair of new 4" speakers.
What year?
- City: Charleston
- State: WV
Thanks. Mine is a 66 and I'll look up there again.
I have 3 '68's 1 '64 and 1 '65 If the truck had a speaker they are all installed like the following picture.
ALL OF THEM.
Even the one where the speaker is missing you can see the washer scuff marks.
Scott
ALL OF THEM.
Scott
http://www.Sweptline.ORG
1965 Dodge SWB D100 (Utiline)
1970 Dodge LWB D100 (Dude)
Thats exactly what I did! Too bad some #@&%$# drilled 2 holes before me.
66 model attaches the same as Scott's.
Scott,HellBellyD100 wrote:I have 3 '68's 1 '64 and 1 '65 If the truck had a speaker they are all installed like the following picture.
ALL OF THEM.
Scott
What size are the factory speakers?
- CSS-Registry
- Administrator
- City: Gainesville, Florida
not to hijack the thread but does anyone have a nice factory speaker for a 1964 for sale?
Ben
Ben
Custom Sports Special
& High Performance Package
R E G I S T R Y
R E G I S T R Y
- City: Charleston
- State: WV
I'm missing more than the speaker.
- CSS-Registry
- Administrator
what all do you need?BobEggleton wrote:I'm missing more than the speaker.
R E G I S T R Y
R E G I S T R Y
Ben Im using a 5" speaker if that helps.
- Jims68
- City: Edgewater Park
- State: NJ
My 68 didn't have a factory speaker in it when I got it... In fact, it was a FORD speaker. BUT, I do remember it had two holes in the dash for speaker screws. They were at the ends, not in a square. So, I always "assumed" it was for a 6X9 speaker, not a round one like your "screws" show. Seems... cheap if you ask me.
My 67 original Mopar speaker was a 5 x 7 with (4) 4-3/8" center to center mounting holes and mounted thru top of dash per Scott's pictures. Purchased an 8 ohm impedance 5 x 7 oval replacement speaker from S M Electro-Tech. It was a perfect fit.
Mike....
http://www.turnswitch.com/speakers.htm
Mike....
Speaker installation. And if anyone needs the radio install instructions with schematics etc for 61 to 68 Radio send a PM with E Mail address for files.
- Red383
- City: Fort Loramie
- State: OH
Every early speaker dash has had the screws through the grille like Scott's pictures.
My non radio dash has no mounting studs of any kind to mount a speaker.
Aaron
Aaron
- martincom
- City: Five Points
Would any one have the bolt pattern dimensions, of the speaker itself, for the speaker depicted in the first photo of nfury8's post (post #3)?
- martincom
- City: Five Points
I received an answer on one of the sweptline FB groups. It is 4.375" square, if anyone else needs to know.
