D100 year ID
Bill
D100 year ID
Post by Bill »
Hi folks,
I'm new here, I've got a D100 parts truck that I'm going to use the engine and trans in a 53 B4B (Dodge).
I need to know the year of the truck, it was hit hard all I have is a few parts.
Can someone give me the year ?
Here are the # from the Vin plate 1161677905
and 16230011
Thanks .............Bill
Try this link that goes back to Kris W old Sweptline site. There is a VIN decoder there. You will need to download the "applet" Thing. OR, maybe someone here already has a version that can do it for you.
http://www.sweptline.com/java/index.html
Bill
Truck ID
Post by Bill »
Thanks Jim,
I had trouble with the applet thing.
Someone may help.
mesman
City: Largo, Fl
Post by mesman »
The best I can make out, it's a "67 D100 wit a /6 built in Warren, MI.Try looking at this site.http://www.sweptline.com/hist/vininfo.html
I always wanted to be a BEACH BUM!
Jeffc
Re: D100 year ID
Post by Jeffc »
Bill wrote:Hi folks,
and 16230011
Decodes as
1)D
1)100
6)225ci (\6)
1)Warren
numbers start in 67 with 668000 for the C serise
so at 677905 it is a Warren truck
the 68 numbers start at 780000
Bill
Thank You and Rear axle bearing
Post by Bill »
Thanks for the info on the ID.
Now more help is needed, I have a 355 rear end that I want to use in the 53 B4B.
The problem is, loose bearing in the axle housing
is there a fix for this ?
Thanks ................Bill
Do you mean "end play"? This can be adjusted on the right side of the rear axle by turning an adjusting collar. OR, do you mean an actual loose bearing? The bearings on an 8 3/4 are pressed onto the axle itself. I am sure that others... (JeffC) on this forum can clarify this better than me. :salut
Bill
Loose bearing
Post by Bill »
Hi, I am talking about the outer race being loose in the housing, the housing at the backing place is worn.
Looks like the outer race was turning in the housing.
