I recently noticed a drip coming from around my fuel pump. After a close inspection, I noticed it was coming from a small port atop the fuel pump. Removing the front bolt was no problem, but I couldn't get a socket or wrench around the rear bolt. What is the easiest way to get this bolt out?
It's a 67 W200 with a 383.
Thanks John.
Fuel Pump Removal Problems
- mudguts
- City: Coalinga
I can type 100 words a minute, but it's in my own language.
67 PW
67 PW
- mudguts
- City: Coalinga
Oops, I didn't sign in, thanks guys, John.Anonymous wrote:OK cudajimmy,I'll give that a shot. Hey guys, I think a flare wrench is similar to a box end wrench with a gap cut out so it can fit over tubes and pressure lines and what not ?
Thanks CudaJimmy
67 PW
67 PW
OK I know what a flare nut wrench is
I thaought it was a flank wrench---snap on flank wrench---
Some of the flare nut wrenches are too thick walled
to get into tight spaces
it's funny that some tools have such different names in different parts of the country
- cudajimmy
- City: Oklahoma
Okay, sorry I didn't get back sooner. Here are some pictures of a flank wrench. It's basically like an open end wrench, but it's got several little "grip" grooves in it so you don't have to get it clear around the nut. I think Craftsman has a similar wrench out now. The one pictured is metric, but I've got a metric and an SAE set. Snap On's run about $450.00 per set, but you can buy them individually, or as I stated before, maybe check out Sears. Hope this helps.
69 Barracuda Notchback 440
61 D100 SWB Poly Auto
- mudguts
- City: Coalinga
Thanks again cudajimmy, you cleared that up for me.
Fredm, I must apologize for my confusion, or drunkeness. After rereading cudajimmys first post without my beer goggles on, I see it is flank not flare.
Thanks guys
I need to stay away from the key board when I'm tuned up, if ya know what I mean.
Thanks guys
67 PW
67 PW
