Rubber floor
fireguyfire
City: Cochrane
Rubber floor
Post by fireguyfire »
The original rubber floor in my 1970 1/2 ton is broken into several pieces and is unusable unfortunately.
Does anyone reproduce rubber floors for our trucks? If not, what are you guys and gals using instead?
Re: Rubber floor
From what I've seen, the rubber mats are not being reproduced anymore. Also, from past posts guys seem to be going with the carpets from ACC.
https://www.stockinteriors.com/AutoCarp ... odelId=160
I cannot say anything about these... I had bought my rubber mat (which doesn't fit that great) many years ago.
BigBlockTrucks
City: Binghamton
State: NY
Re: Rubber floor
Post by BigBlockTrucks »
I pulled the original rubber mat out of mine and found that it was holding moisture under it.
My solution after redoing the floors was to use POR 15 then rust oleum truck bed coating and floor mats. The truck is 4x4 and still gets used as one, so I figured it was better not to have a rubber mat holding moisture under it.
This way I can monitor it by only lifting a floor mat.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
sdenty
City: Buena Park
Re: Rubber floor
Post by sdenty »
I bought the replacement rubber mat from auto custom carpets. It fits OK, but not perfect. Not resto quality ,but a big improvement over my shredded original. Plan on a few hours to cut and fit,actually went all the way up to the fuel tank. I also used factory sill plates i had for a better fit. Ill see if i have any pics.
sdenty
City: Buena Park
Re: Rubber floor
Post by sdenty »
here is the installed mat in my 67 from prior post.
67step100
City: Niagara, ON
Re: Rubber floor
Post by 67step100 »
There is a '67 D200 on BaT at the moment and the floor in that one came from ACC according to the seller. Seller also says it took some fitting and heat to get it go around the bends etc. And also needed trimming. Didn't look too bad.
67step100
City: Niagara, ON
Re: Rubber floor
Post by 67step100 »
sdenty wrote:
Wed Feb 08, 2023 4:29 pm
What seats do you have in your '67?
DukePW
City: Sarnia, ON
Re: Rubber floor
Post by DukePW »
Is there room to fit jute or sound deadener before laying down the new rubber floor?
67 Fargo W100 Utiline
52 International L-110
Re: Rubber floor
DukePW wrote:
Fri Mar 03, 2023 4:04 pm
I used new jute under my rubber floor mat. My mat was a repro job I had bought YEARS AGO.
Wildergarten
City: Los Gatos
Re: Rubber floor
Post by Wildergarten »
Jims68 wrote:
Fri Mar 03, 2023 7:57 pm
I get in and out of my trucks with wet boots and clothes all winter long. Is there such a thing as a soud deadening under-mat that doesn't absorb water?
Re: Rubber floor
Wildergarten wrote:
Sat Mar 04, 2023 9:06 pm
Yep... Dyanmat is waterproof, but I've never used that.
https://www.dynamat.com/products/dynadeck/
Wildergarten
City: Los Gatos
Re: Rubber floor
Jims68 wrote:
Sun Mar 05, 2023 7:35 am
I have some, but not enough to cover the floors. Spendy.
Thanks!
Mark
Re: Rubber floor
Wildergarten wrote:
Sun Mar 05, 2023 10:52 am
Thanks!
Mark
Eh... it's only money... OH; wait a sec... :lol:
