NP435 Outer Shifter Boot? **Reproduction now available**
Fargone
City: Ontario, Canada
Post by Fargone »
I just installed a reproduction of the original boot. Looks good $50 From Mega Parts.
https://www.megapartsusa.com/proddetail ... 106-SB6171
I have recently purchased a 1965 D100 first gen with the NP435. My shifter boot is very brittle and will fall apart if moved. I have the shifter dust boot and retainer on order. But I am having a hard time finding a original outer shifter boot. Are there any companies that still sell them?
I have seen the Omix-ADA 18886.96 Outer Shift Boot replacement for a '97 Jeep Wrangler, it looks close.
What are people using?
Thanks for your assistance.
1965 Dodge D100 Utiline
1951 Dodge DG1 (B3B)
1942 Fargo FL1 (WC)
1941 Chrysler C28 Windsor Club Coupe
1938 Dodge D10 Sedan
Re: NP435 Outer Shifter Boot?
Factory Boot no longer available new. This may work.
https://www.4statetrucks.com/interior/s ... Ad%20group
Fargone
Post by Fargone »
Thanks Texas2step for the link. It looks like the size is 10.5" long.
The Wrangler one; is 6"X 4.5" which seems pretty close to the opening on my flooring.
https://www.quadratec.com/p/omix-ada/ou ... rangler-tj
Just wondering if anyone had installed anything that worked good?
1942 Fargo FL1 (WC)
Fargone wrote:
Thu Aug 25, 2022 9:16 am
How does that attach to the hump? This is what I used in my' 67. https://www.amazon.com/MITZONE-Transmis ... 306&sr=8-3
Fargone
Post by Fargone »
Thanks I like the look of that one, especially with the combined hold down ring.
I'm going to order one tonight.
1942 Fargo FL1 (WC)
Fargone wrote:
Thu Aug 25, 2022 6:21 pm
You have to drill 4 holes in the top ring and attach with sheet metal screws. ( the clips on bottom of the ring are specific to the jeep model and don't work on our trucks. no problem) :Thumbsup
Wildergarten
City: Los Gatos
Post by Wildergarten »
One thing I did with my truck that has worked is to fold a "boot" out of hardware cloth that goes around the transmission tower under the "inner" rubber boot to keep rats and mice from getting up there. Don't know if this is a problem for you, but it has worked for me so far because of the stiffness of the motor mounts on the hydrobell.
Last bumped by Fargone on Fri Mar 24, 2023 1:38 pm.
