windshield moving in
I have a 1962 D200 that the windshield has pushed in and out of the gasket and frame at the bottom while driving. Anyone else have this problem? What is evryone using for gaskets? I used a new gasket when puttung windshield back in.
- martincom
- City: Five Points
Re: windshield moving in
Was it a new windshield?
I sourced my windshield rubber boot from Restoration Specialties.
No Original windshield new seal
No Original windshield new fasket
They're available thru every auto glass shop, as are the windshields.
sounds like seal is too loose
Did you install a lock strip?
- martincom
- City: Five Points
Well, as it is the same cab with no, presumed, modifications that would impact the glass opening and the same windshield. The only item that has changed was the rubber boot. I'd try another from a different vendor.
- martincom
- City: Five Points
The lock strip that is inserted into the channel within the weatherstrip, to lock it firmly in place.
Yes
Locking strip installed What is everone using for rubber seal?
