Need 1970-71 D100-200 Front Bumper, Valance & Grille
Deazel
City: Chicago
State: IL
Post by Deazel »
Hi All,
Got in a front end collision with my beloved 1970 D200 Camper Special.
I'm looking for a front bumper (chrome), front grille (Aluminum) and front valance panel.
Thanks in advance for any suggestions.
1970D300
City: Carlisle
State: PA
Re: Need 1970-71 D100-200 Front Bumper, Valance & Grille
Post by 1970D300 »
Grille is the same as 1970-71 D300 and W300 also.
1972-74 400 commercial models too if that helps?
jeffc57
City: vancouver
Post by jeffc57 »
front bumper can be straitened and re-chromed by good bright chrome shop, local one to me would do it for around $600plus
martincom
City: Five Points
Post by martincom »
I had an extra grille, but it has some dings, and was missing the two left plastic inserts. I sold it to a friend for garage wall art. I'm thinking the aluminum wouldn't straighten well. However, if you need the right plastic inserts, I could reach out to him.
Deazel
City: Chicago
State: IL
Post by Deazel »
Thanks for the information and help.
Thought I had a line on the grille and valance, but still no luck.
I'll see about straightening the bumper.
That piece you call a "valance" is part of the core support and is welded to it.
Deazel
City: Chicago
State: IL
Post by Deazel »
Hmmm, I'll have to check that out.
I'm talking about the lower panel under the grille, directly behind the bumper.
Found a grille from Bonanza Auto Dismantlers in CA FYI
Thanks again
jeffc57
City: vancouver
Post by jeffc57 »
yes, core support, bolts to frame behind bumper and holds radiator
Deazel wrote:
Tue Feb 08, 2022 10:16 am
I'm talking about the lower panel under the grille, directly behind the bumper.....
Yup, that piece is welded to the core support. Could cut all the welds to remove and replace it, but you would be looking for someone else to do the same in order to sell you just that part.
If you are looking for parts closer to you, Doug's 4-Wheelers in Pella Iowa would have all the parts. He might not have any parts in perfect condition, but you could look in person.
Thanks again
Did you check the back side of the radiator? Damage like that almost always flexes the core support back and bumps the radiator into the fan.
Deazel
City: Chicago
State: IL
Post by Deazel »
I'll take your word for the valance panel being welded to the core support. I don't see any spot welds (pics attached). Guess I'll find out when I try to take it apart. (Waiting for the parts to come in) Had a few bone yards say they can offer me a "front valance panel", hopefully they know what they're in for.
I replaced the transmission cooler and re-cored the radiator. A few pieces of plastic poked through the front of both, but luckily the impact stopped short of moving the core support and radiator. The truck drives fine now. The front end damage is a head turner on the street though. Used to be everyone would smile and wave seeing the truck, now they just wince and shake their heads!
There's a small bit of paint popped off the frame just an inch or two back from the bumper mounting brackets, but no other paint loose on the frame, so it doesn't appear that the frame's damaged or moved (much). passenger door closes just slightly different than before, hopefully fix that with a hinge adjustment, but other than that all panels seem lined up OK too.
I'll give Doug's 4-Wheelers in Pella Iowa a call... Still hoping for a bumper. Straightening the damaged one would be a chore. The bolts are punched through and the thing is a pretty good pretzel. I have the skill to do it, but it would take a lot of labor time. I paid insurance for 25 years with no accidents, so I'm hoping to have a shop do at least part (or most) of the work. Local shop said they can "try" to straighten the bumper, but it would definitely looked damaged after the repair. I did find a painted bumper, thinking I could probably sandblast it and and have it chromed? Anyone done that?
Thanks all
-D
There is a bolt on front valance on the 300 and up trucks. It attaches below the painted section you see on your truck below the grill.
btw - I have an NOS chrome bumper if you got the money.
jeffc57
City: vancouver
Post by jeffc57 »
why you don't see the welds, is they are "pinch" welds, small spot welds that are hard to see. The top of the fender over the wheel to the outer fender are held the same way. Pinch welds can be drilled out and chiseled apart,
Deazel
City: Chicago
State: IL
Post by Deazel »
jeffc57 wrote:
Fri Feb 11, 2022 8:55 am
I checked the parts manual and see that you all right about that piece being part of the "radiator grille panel support".
Makes me wonder what they're going to send me from the yard I bought the "valance panel" from :(
PwrWgnDrvr wrote:
Thu Feb 10, 2022 7:47 pm
PwrWgnDrvr I sent you a PM... I'm interested
Thanks again
jeffc57
City: vancouver
Post by jeffc57 »
" I did find a painted bumper, thinking I could probably sandblast it and and have it chromed? Anyone done that?"
yes it can be done, however, it doubles the cost of the plating, and as you said needs to be a clean surface. It has to be dipped more times than a bumper that is sent-in for a re-dip. So, much better to find a chrome good bumper, or strait (or close to strait) one that needs re-dip.
Bright chrome shop gave a price of $1200 to do one I have if I strep it clean, $600 if already chrome
Deazel
City: Chicago
State: IL
Post by Deazel »
jeffc57 wrote:
Tue Feb 15, 2022 12:28 pm
Thanks for the info.
martincom
City: Five Points
Post by martincom »
The bumper shop in my hometown is still doing straightening and re=chroming of bumpers:
https://www.northstarplating.com/
They were acquired by Keystone a number of years ago.
