Hello All.
I have a couple of questions. I am pulling my clutch, brake pivot shaft. To clean up and lube to cut down on the squeaking. Before starting to pull it I searched the website to find hints and tips. Like always a good idea before I start a venture. I seen one post mention that the bushings are still available. Does anybody know where or part numbers? I cannot find them anywhere.
2nd. While searching for those parts I was on RockAuto and noticed they have interior sun visors for sweptlines. I am in need of and thought they were unavailable. They have them listed for 63 and newer. My truck is a 62 D100 Custom and I am 99 percent sure the 62 and 63 are the same cab. Can someone back me up on that before I order them.
Thanx.
SL.
Clutch n Brake Pivot Bushings.
- City: Doylestown
- State: OH
Re: Clutch n Brake Pivot Bushings.
I think you can still get needle bearings for that pedal pivot shaft. Mine were Pedal bearing Torrington S-1212 or Koyo B-1212.ScrooLoose wrote: ↑Sun Dec 20, 2020 2:02 pmHello All.
Thanx.
SL.
M
- martincom
- City: Five Points
Are these what you are seeking the plastic bushings? If so, **NOT ALLOWED** has them. I would have posted the link, but forum remove the name and replaces with "Not allowed".
- martincom
- City: Five Points
**NOT ALLOWED**
I give up.
I give up.
- City: Doylestown
- State: OH
Maybe you can give me a hint.
"Sounds Liiiiike"
"Sounds Liiiiike"
I see it posted just fine above.
Here's a hint.
You gotta take it easy.....
Down on the corner, out in the street, Willie and the poor boys...
My Grandma's favorite flower is the LiLaC bush.
Here's a hint.
- City: Doylestown
- State: OH
Riddle Solved.
Thanx man.
SL.
Thanx man.
SL.
