Started floors
Volksnut
City: Winter Park
Started floors
Post by Volksnut »
It sucks to repair rusted out floors, worse yet when they've already been done....I'm assuming the new floor panel is tacked to that body mount?
Series1Utiline
City: Newberg
Re: Started floors
Post by Series1Utiline »
I'm not sure on the answer to your question but others will surely know. It would be good to see you document your sequence of the floor repair (if it's not too late). Did you use a spot weld cutter on the floor edge seam at the edge of the step?
Volksnut
City: Winter Park
Re: Started floors
Post by Volksnut »
Series1Utiline wrote:
Sat Oct 03, 2020 5:48 am
No, I'm not done cutting yet. I'm replacing an already patched floor which will be continued into the step area so I'll be cutting farther down. I'm getting pictures as I go.
quickgraffix
City: stockton
Re: Started floors
Post by quickgraffix »
you definitely had to cut a lot out but i think most of us here had to do the same thing just in different degrees of repair..i had to replace both sides on mine you could Fred Flintstone mine when i first picked it up
Re: Started floors
Volksnut wrote:
Fri Oct 02, 2020 2:22 pm
The floor pan is independent from body mount. It bolts to it and has washers, spacers.
Re: Started floors
This topic has diagrams from the service manual:
viewtopic.php?f=30&t=29374
Volksnut
City: Winter Park
Re: Started floors
Post by Volksnut »
wally426ci wrote:
Fri Oct 16, 2020 6:40 am
ahh yes, knew there was a little extra room for an extra rubber mount
Volksnut
City: Winter Park
Re: Started floors
Post by Volksnut »
Little update, passenger side is done, had to add quite a bit of metal beyond the patch panel, and remember this isn't a concours truck, just a daily driver.
Re: Started floors
:Thumbsup :Thumbsup
Red383
City: Fort Loramie
State: OH
Re: Started floors
Post by Red383 »
Looking good.
Re: Started floors
looking good. i have done at least 3 trucks now. getting better on each one.
