The driver's side door on my 64 series I has felt like it was dragging between the cab latch and the star wheel on the door. I sprayed the star wheel lightly with silicone lube and while the door now closes easily, the door doesn't stay latched (in the 2nd or fully closed of the 2 latch positions). Not having messed with the door latch mechanism before, just curious if the symptom I mentioned is typically a star wheel issue as mine does look a bit worn. I don't see adjustments in the door wheel mechanism although I realize the door can be adjusted at the hinges (fore and aft as well as in & out to some degree). I also see that the cab latch could be bent as needed for some adjustment there.
I've not spent anytime on corrections as I was working on another detail at the time this cropped up. It would be good to know how others have addressed similar symptoms.
- EM
Door Adjustment
- City: Newberg
Re: Door Adjustment
Star wheels wear, but even worse the door hinge pins wear and the door drops down at the latch end. This causes the latch to drag across the top of the strike. You can feel the extent of the hinge pin wear by lifting up on the door while it is open. Temporarily you can try to adjust the hinge bolts inside the door to lift it back up. Look for alignment along the body sweptline at the door/cab.
- City: Newberg
Re: Door Adjustment
I should have mentioned that the original owner that I bought my truck from had the door open WHILE backing up and then hit something with the door that jambed it forward into the hinge. That surely didn't help. As a result, I have an excess in the gap at the rear of the door and almost none at the front. But, I'll check the hinge pin wear as I did have a burr on the front edge of the latch on the cab.
I'm also giving thought to investment casting a small batch of the star wheels.
- EM
- EM
Re: Door Adjustment
Powerwagonjohn already has them available.earlymopar wrote: ↑Sun Sep 30, 2018 7:14 pm
- EM
John Geidl 651 653 0147 or cjlapham44@gmail.com
- City: Newberg
Re: Door Adjustment
Thanks much. I'll be sure to contact him.
- EM
- EM
Re: Door Adjustment
Rebuilding an early door latch is a daunting task. John Geidl rebuilds those.FYI.earlymopar wrote: ↑Sun Sep 30, 2018 7:14 pmI should have mentioned that the original owner that I bought my truck from had the door open WHILE backing up and then hit something with the door that jambed it forward into the hinge. That surely didn't help. As a result, I have an excess in the gap at the rear of the door and almost none at the front. But, I'll check the hinge pin wear as I did have a burr on the front edge of the latch on the cab.
- EM
- City: Newberg
Re: Door Adjustment
Thanks for the heads up on these sources.
- EM
- EM
