Correct Door Assembly Procedure
I am just finishing up painting my doors and was hoping someone with a little experience re-assembling the doors would chime in. What is the correct sequence to re-assemble the door mechanisms. Do I install the glass surround first? or I'm thinking install the vent window and glass into the surround first, then install the surround to the door. Any help would be appreciated...
- jwing68
- City: Lethbridge,Alberta
Re: Correct Door Assembly Procedure
I wrote some notes when I did mine.
1. Lay the door flat outside down
2. Install the door latch
3. Lay window regulator & glass in door
4. Attach regulator to glass inside the door
5. Bolt regulator to door- leaving window down
6. Install upper door frame with vent window attached to upper frame.
7. Install door handle & related mechanisms
8. Install window whiskers
9. Install channel run seals
10. Stand back & admire your work.!
66 Fargo W100 Sweptline SWB Poly 318
67 Fargo W100 Sweptline SWB Poly 318
68 Fargo W300 dually LA 318
66 Dodge W200 Poly
65 Dodge W300 dually Poly 318
68 Pontiac Firebird 350
2005 HD FXST Custom
66 Dodge W200 Poly
2005 HD FXST Custom
That's awesome, thank you so much.
