Front fender to cab attachment
Posted: Tue Mar 28, 2017 6:58 pm
by SoleSurvivor
It appears the fender to cab attachment is missing on the passenger side of my truck. So much so I have to push the upper side fender top inwards to open and close the door. Inside The fender looks to have a 1/2 by 1/2 inch opening that something is supposed to go into. The inside cab has a 2 inch access whole in the kick panel, I assume, to gain access to what ever needs to be tightened down. Any ideas how to secure the fender to the front of the cab just in front of the door?
Re: Front fender to cab attachment
Posted: Tue Mar 28, 2017 8:08 pm
by allsupj
There should be a caged nut in that hold. May have rusted away and fallen out.
Posted: Tue Mar 28, 2017 9:21 pm
by dodgeboykim
Posted: Wed Mar 29, 2017 7:22 am
by SoleSurvivor
The fender is in perfect shape. But that cage nut is missing. What size should I be looking for? And thanks. I figured there had to be some time of nut that goes there in addition to the one that sits behind the steering wheel,
Posted: Wed Mar 29, 2017 9:43 am
by PwrWgnDrvr
To get to it u will need to remove the fender. Be prepared for a long and grueling process. There are multitudes of bolts to remove, many of which are likely rusted in place.
FYI, 1 ton fenders are unique to 1 tons and quite difficult to find. Treat it with love.
Posted: Wed Mar 29, 2017 10:20 am
by SoleSurvivor
PwrWgnDrvr wrote:To get to it u will need to remove the fender. Be prepared for a long and grueling process. There are multitudes of bolts to remove, many of which are likely rusted in place.
Luckily...the truck was fitted with w200 fenders. Still a bunch of bolts holding it on. And I can get a needle nose plyers in there with a cage nut. Just have to get the right size nut to snap into place.
Posted: Fri Mar 31, 2017 3:26 pm
by robertob
