Wiper arm removal issue
Posted: Tue Feb 21, 2017 2:30 pm
by crashresq21
So I removed my wipers to take the cowling off, cleaning out the dumpster of 40 year old crap in the trough. Is there a trick to put them back on? Here's my issue:
1)Swing arm portion had the tension strength of Stallone in Over The Top. Bear to flex to install AND turn the nut.
2) The nuts (both) built into the arms won't catch the threads and I fear I might have stripped one of the studs.
Are there other EASIER and less profanity laced options to replace them?
Thoughts?
Re: Wiper arm removal issue
Posted: Tue Feb 21, 2017 5:27 pm
by ozzie
the way I did it on my 69W200 was, I lined up the arm over the spline, and took a small hammer and tapped it down until it grabbed onto the spline, and then got a socket on the nut and tightened down. didn't have a problem doing it that way. just make sure you are lined up.
Posted: Tue Feb 21, 2017 5:39 pm
by MadMC63
Place the arm over the threaded portion. Grasping the arm in the palm of your hand use the splined portion to pry against slightly. Your thumb will be against the nut pushing down while you pull up on the arm to flatten it out. This should give enough to start the nut. Don't hulk out or you'll have a separate arm and nut. You giggle it back and forth as you tighten.
Posted: Tue Feb 21, 2017 6:23 pm
by crashresq21
MadMC63 wrote:Place the arm over the threaded portion. Grasping the arm in the palm of your hand use the splined portion to pry against slightly. Your thumb will be against the nut pushing down while you pull up on the arm to flatten it out. This should give enough to start the nut. Don't hulk out or you'll have a separate arm and nut. You giggle it back and forth as you tighten.
"Hulked out" happened awhile ago. Both are officially separate from the arms. I checked the nut on the shaft, seems to not want to catch, threads FUBAR?
Posted: Tue Feb 21, 2017 7:41 pm
by MadMC63
Check the end of the threads on the stud and make sure they're ok and if they are put the nut on the stud and push down slightly while turning the nut backwards. If the nut isn't badly damaged you will feel it drop slightly when the treads match up and then you can try screwing the nut in place. If that doesn't work you will need to use a bottom tap on the nut and a die on the stud.
