D600 body panels
crashresq21
City: Lincoln
State: RI
Location: Manville RI (no seriously, its a village. The day they named the place was a slow day mentally.)
D600 body panels
Post by crashresq21 »
So as if one 71 wasn't enough, I found this ex railroad company W600 locally. Damn solid mechanically but fenders are razor thin cheese grater quality rust sheets. I can fab up the front drop panel but are there any aftermarket fender panels?Can I use any other quarters? D100 etc?
"Dealing with me is like playing chess with Charlie Manson. 99% of the time you're like 'this guy is on his game', and then there's the one time I shove a pawn up my @#% and dance around"
Re: D600 body panels
To keep it looking proportional you need fenders from a 500/600/700/800 series vehicle. The W500/600 have a larger "lip/flare" than the D series.
100/200 & 300/400 series will I think bolt up but may look puny.
crashresq21
City: Lincoln
State: RI
This is the monster in question. Note the fender is pretty much cheesecloth. Reportedly the front end was custom-built by a separate company (Shuttle Corp.) judging by the narrow width track for railroad work. I was told it has a napco axle and a new process transfer case with PTO. Onboard compressor that is belt driven also.
Normally W600's have Rockwell drivetrain (T-case & axles). Tough looking rig.
That is rad. I bet Kenny Exline could build you what you want. You could probably have him do wheel lips and you'd use smaller fenders. He is a one man shop in PA and a great person. :salut
http://www.exlinecustomauto.com/
Dodge did not make W600 Sweptlines. It is a D600 converted aftermarket to 4x4. The D700 I saw converted with Napco stuff also had p/s.
PwrWgnDrvr wrote:Dodge did not make W600 Sweptlines.
They did in 72 and 73.
Yep the W500 designation was "retired" after 1971.
I'd like to see more pictures of that rig.
3deez
City: St. Johnsville
State: NY
Post by 3deez »
PM sent.
