Radiator support color
- pwadventurer
Is the radiator support flat black front and back above lower area or can it be body color? I am going with B-5 blue body color.
- Jims68
- City: Edgewater Park
- State: NJ
Re: Radiator support color
My 68 was black in the front where you can see through the grille, and COLOR of the body on the back side (engine compartment). However, when I repainted my truck, I FORGOT that the backside was COLOR and painted the whole thing black. Oh well... still looks good and nobody has ever said anything.
- pwadventurer
Thanks Jim, I've seen a few trucks full body color and it looks good. I wasn't sure if it was an option or standard. The 70 has the grill insert, not sure how much will be visible. I'll have to assemble an see.
- Jims68
- State: NJ
I just read your original post again and seen that you mention flat black. I would say the support should be more of a Semi-Gloss black. The paint on mine was so faded. I like the look of black behind the grille.
The TWO parts trucks I had which were BOTH 1970 trucks had the BLACK on the front side The Body COLOR of my YELLOW 1970 D-100 was painted on the engine compartment side.
I cannot positively confirm the color of the engine compartment side on the D-200 1970.
Mine is black on grill side and body color on engine side. Chrysler cars were the same way. The black makes the grille color pop. Body color behind the grille looks out of place and takes away from the grille.
- pwadventurer
Thanks guys, I'm going with the semi gloss black BC/CC in the grill area and body colors for the inside and lower section.
- Jims68
- State: NJ
Sounds GOOD!pwadventurer wrote:Thanks guys, I'm going with the semi gloss black BC/CC in the grill area and body colors for the inside and lower section.
And my 66 that has a 68 rad support on it is black on the backside. Came from a US built truck. Kept it that way 34 years ago.
- pwadventurer
What was the body color of the 68? And is the rad support black in the fender well area too.
My truck is Red with white roof. In my Avatar pic.
- pwadventurer
Yes, that's a nice looking truck. I didn't know if the 68 rad support you put on the 66 was red to begin with. Interesting some were black on the engine side and some body color.dodgeboykim wrote:My truck is Red with white roof. In my Avatar pic.
Went out and looked at some of my parts trucks in back field.
66Dodge D100 appears to be mostly black on back side. Really hard to be sure due to surface rust.
66 Fargo w 200 also appears mostly black on back side.
68 Fargo D100. Black on back side. Some body colour over spray on it.
64 Dodge D100 Black on backside with repaint over spray.
Did not check my 70 Fargo D500.
If they were sprayed black over body colour the surfaces have deteriorated just badly enough to not be positive on original colour.
- Commando66
- City: Gig Harbor
My 69 D100 Adventurer is black on the front and body color white on the engine side.
[IMG]http://i270.photobucket.com/albums/jj104/Commando66/DSC03735_zps507e925c.jpg[/IMG]
- pwadventurer
Is your truck an original west coast truck?? Just wondering if east coast vrs, west coast or may by 61-68 black and 69-71 body color.Commando66 wrote:My 69 D100 Adventurer is black on the front and body color white on the engine side.
My East Coast 71 is body color inside and black outside.
1971 Dodge D100
Would splitting by manufacturing plant make more sense than where it was sold new? Michigan, Missouri or Canadapwadventurer wrote: Is your truck an original west coast truck?? Just wondering if east coast vrs, west coast ...
- pwadventurer
Yes, that would make more sense.soopernaut wrote:Would splitting by manufacturing plant make more sense than where it was sold new? Michigan, Missouri or Canadapwadventurer wrote: Is your truck an original west coast truck?? Just wondering if east coast vrs, west coast ...
- Commando66
- City: Gig Harbor
Yes, bought new in California then it came to Washington in the mid 70's.pwadventurer wrote:Is your truck an original west coast truck?? Just wondering if east coast vrs, west coast or may by 61-68 black and 69-71 body color.Commando66 wrote:My 69 D100 Adventurer is black on the front and body color white on the engine side.
- pwadventurer
I finished the rad support today. this was my first go with spray gun using all components. I used BC/CC blue and single stage hot rod gloss black on front side and all blue engine side. http://i1356.photobucket.com/albums/q73 ... 6teizm.jpg[/img][/url]=145886949&filters[recent]=1&sort=1&o=1
That looks darn nice!! Why body color inner fenders?
1971 Dodge D100
