hood hinges
- rickharrold
- City: blackwell
hood hinges
Anybody have any luck rebuilding hood hinges so hood will set down in back without using a stack of shims?
Re: hood hinges
Guess you are elected to be the 1st to try. Movement appears to be in the riveted hinge pins wallowing out. You can see the movement when you slowly move the hood in the up position. Guess you could drill out and use a larger pins.Same theory as the door hinge pins.
Re: hood hinges
come up with a fix and tell us. I have 1.25 inches worth of shims to bring the back of hood down, no lie. Ive tried EVERYTHING and this is the only thing that works. Either my hood is bent, or hinges are bent or worn.
Re: hood hinges
Appears the rivets get wallowed out over time. If you open the hood and move it up and down, you can see the movement in the rivets. Wonder if you could remove the rivets and replace with larger bolt to take out the slack.68fish wrote:come up with a fix and tell us. I have 1.25 inches worth of shims to bring the back of hood down, no lie. Ive tried EVERYTHING and this is the only thing that works. Either my hood is bent, or hinges are bent or worn.
Re: hood hinges
Did you ever put this idea to the test? Results?Txas2step wrote: ↑Thu Feb 09, 2017 8:57 amAppears the rivets get wallowed out over time. If you open the hood and move it up and down, you can see the movement in the rivets. Wonder if you could remove the rivets and replace with larger bolt to take out the slack.68fish wrote:come up with a fix and tell us. I have 1.25 inches worth of shims to bring the back of hood down, no lie. Ive tried EVERYTHING and this is the only thing that works. Either my hood is bent, or hinges are bent or worn.
Would love to know in order to get my hood to drop down to the right level.
Thanks
Brett Pitts
'64 D200 318 Poly
'64 D200 318 Poly
Re: hood hinges
Sorry, never attempted to do this....yet.
