A/C box- inside- far right side.? box
crossy
City: Pennsville
Post by crossy »
I Did some REAL looking into this A/C system today. it appears that there is some sort of distribution box missing off the far right side behind glove box. There had to be some sort of flapper in that end though with a vacuum pod to control it, because as I said before, there are two vacuum lines there that are not hooked to anything. when I look in the hole -I can see the evap core inside , dead center behind the center dash vents. .
I also have two small tubes that come through the firewall on the engine side directly behind right valve cover, and I am wondering what those tubes were for ?? thanks - Crossy
OHHH! you definitely can't buy that new ! (boy, does that fit these trucks)
MrMopar
City: Lompoc
Re: A/C box- inside- far right side.? box
Post by MrMopar »
The tubes can be seen here and are for the heater hoses.
Alan
Alan Erland
1967 Plymouth Barracuda
1969 Dodge Polara CHP
1969 Dodge Polara
1970 Dodge Camper Special
www.MrMopar.com
MrMopar
City: Lompoc
Post by MrMopar »
The missing section looks to be the blower housing.
Alan
Alan Erland
1969 Dodge Polara
www.MrMopar.com
