Hole under headlight switch
- City: Santa clarita
Hey guys, been trying to figure out the factory hole about 3" under the headlight switch on the left side of the steering wheel on my 71 dodge. Pics online I've seen show other trucks with the same hole. What's it for?
Thanks in advance
Thanks in advance
- powerwagon54
- City: Washougal
Re: Hole under headlight switch
choke cable
I thought it might be that but I thought the choke cable is next to the ash tray? Different models I guess?
Would it be for a vent cable?
The original choke cable would've gone there. Trucks with factory electric choke had plastic plugs covering that hole.
John- the vent cable is underneath there on mine
I guess it can be choke it was blocked off. My buddies 71 d100 has a 318 and the choke is next to the ash tray which is why I didn't think it would be all the way over to the left.
Thank u for the info
I also concur. Choke cable if equipped to left of steering column under headlight switch.
- MrMopar
- City: Lompoc
Mine had a switch for the gas tanks, this only did the gauge not the actual valve.
Alan
Alan
Alan Erland
1967 Plymouth Barracuda
1969 Dodge Polara CHP
1969 Dodge Polara
1970 Dodge Camper Special
www.MrMopar.com
1969 Dodge Polara
www.MrMopar.com
Ooh! I like that set up. Since I'm running dual tanks. May have to mock something up for that
- City: Pennsville
- State: NJ
My 69 was like Mr. Mopars since mine has a pair of travel tanks- I can see where the sticker was , but the switch and the sticker are gone now . the tanks remain. d:-)
OHHH! you definitely can't buy that new ! (boy, does that fit these trucks)
