I have some hood hinges on my 65 PW that were apparently damaged when the hood was over-extended backwards. I got another set off a donor truck that was a later model (69-70?) and they appear very similar, except there is an extra set of short springs attached to a metal tab on the set from the donor truck. Did they change the design or am I just missing the spring and metal tab?
Hood Hinges - What's the difference?
Re: Hood Hinges - What's the difference?
2 different versions used from 61 to 71 and just dictate how far hood opens. Do not mix different styles.
Ok, thanks! So don't mix left and right with different styles but sounds like I should be able to swap out the old set for the newer style right?
daveleast wrote:Ok, thanks! So don't mix left and right with different styles but sounds like I should be able to swap out the old set for the newer style right?
