How do you remove the bed ends? the end caps that hold the tail lights on the 65 fleetside?
thanks. picts too if you have em!
bed corner removal?
Re: bed corner removal?
shopguy wrote:How do you remove the bed ends? the end caps that hold the tail lights on the 65 fleetside?
Early 65 or late 65 . Removal requires locating spot welds and drilling them out. Not a fun job on those end cap areas.
yeah...thats what I thought. No rot, but a small dent to fix in it. thanks!
Can you weld a pin to it and yank it instead of cutting it apart?
stud puller will work. ez nuff.....
