Front End
Posted: Wed Dec 16, 2015 9:05 am
by 65Shoptruck6
The bolts on the sheet metal on the front end is rusted and I cant seem to get them to budge with a ratchet and pliers. Any suggestions as to how I can get em out?
Re: Front End
Posted: Wed Dec 16, 2015 11:45 am
by WD
Penetrating oil and heat. If that does not work, impact wrench. Last resort, sizzling blue wrench (cutting torch).
You will get them out. And use a box wrench, not pliers.
Re: Front End
Posted: Wed Dec 16, 2015 11:49 am
by Hobcobble
65Shoptruck6 wrote:The bolts on the sheet metal on the front end is rusted and I cant seem to get them to budge with a ratchet and pliers. Any suggestions as to how I can get em out?
Are you using a six point socket?
Re: Front End
Posted: Wed Dec 16, 2015 10:12 pm
by builder
actually based on your question , i am thinking you need to get a propane torch , heat the nut not the bolt use or penetrating fluid, a socket with less points will give you a better grip or a box end wrench, if it does not brake loose twist the bold right off the nut. I'll be doing the same soon , i got lotsa rust , in fact i dont know if the truck is red or rust
Re: Front End
Posted: Thu Dec 17, 2015 8:19 am
by Hobcobble
Another suggestion.....
Tell us exactly which bolts you're having problems with.
It might lead to a few more suggestions from members.
Re: Front End
Posted: Thu Dec 17, 2015 8:44 am
by RussRoth
If you can get to the threads heat them enough to melt candle wax. The wax will suck into the threads and many times you can unscrew the nut pretty easy. Doesn't work every time, first time, but often enough it is my choice in a situation like this if you can do it.
