fender nut clips
- City: kelowna
fender nut clips
Looking for a picture of the nut clip that goes at the top of the fender. The one that is bolted from the inside of the cab. This clip seems different from the others. I broke the bolt when removing the fender and have no idea where the clip went. thanx
- ozzie
- City: colorado springs
Re: fender nut clips
it's not a clip. it' a rectangular nut that stay on the bolt. you have to turn it so the nut catches the inside of the fender, which I rectangular like the nut. you have to turn the bolt so the nut is in the vertical position. you can't see it so you just have to feel when it catches. Ozzie.
ozzie
- City: kelowna
thanx for the info. Can I buy this, like at napa or should I make one.
- Jims68
- City: Edgewater Park
- State: NJ
The factory "Nut" is tack welded into the fender. It's just a square nut... nothing special. You can use any 5/16" nut but you need to weld it into that area of the fender. Hope the pic. helps!
- Cody100
- City: Inwood
So that's why I'm getting a rust spot starting at that point...
Cody
1966 D-100 Custom
1966 D-100 Custom
- Jims68
- State: NJ
Cody100 wrote:So that's why I'm getting a rust spot starting at that point...
'Fraid so... that builds up dirt etc behind that area and walla! Rust!
- DukePW
- City: Sarnia, ON
I ran into this issue a few weeks ago while putting my fender back on. I'll include I picture of what the square nut looks like. I didn't like the thought of re-using this, it would seem almost impossible to align the nut and bolt.
I used a spring nut and grinded it as small as I could get it and put it in to the pocket. The spring tension holds the nut in place, and I used a stainless bolt and fender washer.
67 Fargo W100 Utiline
52 International L-110
- Jims68
- State: NJ
That's a good idea too!!
