Body & floor pans Q
reallylongnickname
City: Ottawa, Ontario
Body & floor pans Q
Post by reallylongnickname »
Last edited by reallylongnickname on Tue Jul 28, 2015 3:45 pm, edited 5 times in total.
DukePW
City: Sarnia, ON
Re: Rusty roof
Post by DukePW »
depends, how much time, money, and ability do you have?
67 Fargo W100 Utiline
52 International L-110
reallylongnickname
Re: Rusty roof
Last edited by reallylongnickname on Tue Jul 28, 2015 7:26 am, edited 1 time in total.
reallylongnickname
Re: Rusty roof
exline
City: warfordsburg
State: PA
Re: Rusty roof
Post by exline »
if it is as bad as it looks in the picture I would cut that section out and weld in a new piece of metal. once metal gets rusted and pitted that bad its hard to keep it from coming back. I use the sharp object test. use a nail or something pointed and if you can push it through the metal at all you need to cut that metal out. otherwise you will end up with small holes that you cant see in the metal and it will bleed through the paint after you paint it. I don't care what kind of body filler you use, all metal, tiger hair or what ever. if it is thin enough to poke a hole in and it is not cut out it will eventually come back. :2cents
reallylongnickname
Re: Rusty roof
The pic is misleading then. There is plenty of good metal. the area can absolutely stand up to sand blasting. *without any creating any holes and eating through that is.
reallylongnickname
Re: Roof n Body
I went around w/ this flathead screw driver what ever metal you see in pics, survived the screw driver. This the driver's side, passenger side is twice as good. Q is, is this a patching job or replacing? I'm thinkn I could cut out and replace with sheet metal.
reallylongnickname
Re: Roof n Body
What gauge of metal are the floor pans? 18 GA?
poorboy4wd
City: barrington
State: NH
Re: Body & floor pans Q
Post by poorboy4wd »
I believe exline uses 18 where others have used 20. Not 100% on original but I want to say 18 or 19 from factory. I used 16 because it's what I had but it's a bear to work with sometimes.
Hand me my hat. Excuse me man, where's the door
poorboy4wd
City: barrington
State: NH
reallylongnickname
Thanks poorboy, I had no idea about this website.
Cody100
City: Inwood
Post by Cody100 »
Wow so glad you posted that Exline website :Thumbsup I thought I was going to have to start piecing my truck together from ebay
Cody
1966 D-100 Custom
ischilf
City: Helena
State: MT
Post by ischilf »
I wish there was a way to bookmark this thread. I am going to be needing to order a few panels from the website. Great resource!
