I put a Grant steering wheel in my '61 Ute the other day. I used the 3314 mounting kit. Other than the vague, photocopied instructions and having to provide my own contact cement for the horn fitting, it went well. Except that there's no provision for canceling the turn signals. The piece from the original wheel won't fit on the Grant parts and there's no provision on the adapter to place the roll pins that were included. Has anyone else run across this problem? Would the solution be as simple as drilling a couple of holes in the adapter and fitting the pins myself?
Grant Steering Wheel and Turn Signals
Re: Grant Steering Wheel and Turn Signals
I installed one on my '68 f100 years back. Had an adaptor kit. Very simular set -up on column as the swept. All above the upper cup .
