Will a door that does not appear to have ever had the three hole mirror post still have the backing nuts for those three big philips screws?
Thanks jim
3 hole mirror post backing
Re: 3 hole mirror post backing
There is a possibility. Can you remove the door panel and run yourJim100 wrote:Will a door that does not appear to have ever had the three hole mirror post still have the backing nuts for those three big philips screws?
Thanks jim
hand up into that area? Just a thought.
If it is the passenger side, it will have the holes through inner skin( you can see them with the door panel off. Not sure about the drivers side.I have never seen one w/o the holes.
passenger side. I will remove inner door panel to check but was hoping to not have too as I have a stripped set screw on both the inner door handle and window crank!
Thanks jim
Thanks jim
As was suggested the three holes existed through the inner skin on my passenger side door. No nuts in there but you cant have everything.
Thanks all
jim
Thanks all
jim
- City: 19067
- State: PA
Anyone know the thread size of those three screws
Believe they are 5/16 NC.
