Need some clarification on cabs.
Will a 69-71 cab (D100-D200) work on a '68 (D100-D200) truck. They sure look the same stripped down. Am i missing a difference somewhere?
Cab Differences
Cab Differences
http://www.Sweptline.ORG
1965 Dodge SWB D100 (Utiline)
1970 Dodge LWB D100 (Dude)
Re: Cab Differences
It will work however there are some differences. I believe the outside dimesions are exactly the same. Some differences are wipers, pedals and dash. I'm sure others will be able to point out the specifics but I don't think the things mentioned above directly swap without modification. One thing specifically is that the clutch went from hydraulic to mechanical and from what I hear it isn't easy to swap one out for the other. If they are automatic trucks it simplifies things.
Re: Cab Differences
You're better off using a '61-'68 cab. The clutch is the biggest thing. The wiring bulkhead is different. To doHellBellyD100 wrote:Need some clarification on cabs.
a swap for an auto tranny truck.... things are a bit simpler but the column shift ['69-'71] becomes an issue
due to the bell c-member being where the linkage Z-bar/bell-crank is located on later trucks. I'm using a
'70 cab on a '68 short frame but am using a B&M [automatic] floor shifter. Dashboards changed in design
& mounting.... a bit of a PITA to substitute one for the other
Re: Cab Differences
Thanks guys, great info, I'll figure out another way.
This '70 cab i have has such cherry floors i don't want to cut it up.. i want to use it.. LOL
