side vent window removall???
wondering how to remove the vent wing windows out of my 68 d200 found a good replacement sets but need to get these out, any help will be greatly appreciated
Re: side vent window removall???
not sure if yours is the same as mine i have a 71 and just did this to mine...there is a screw and the bottom and another one under the rubber on the top side...not sure if you have taken the whole upper half of the door off but you will have to...there are 2 bolts on door jam side...to on hinge side and 2 on bottom and then a bolt on the inside that you can access through a hole on the inside of the door....maybe this will help
It is my understanding that this is one of the biggest pain in the a** procedures to have to do on these trucks. This is not a 10 minute job.
it is a very big pain...can be a 10 minute job if you have a perfect truck with no rust inside the doors makng the screws and bolts harder to get loose lol but im sure there isnt one
- nfury8
- City: KC, MO
Huge pain!!! 6 months later, my new seals don't seal as well as the old worn out ones do!
Still fiddling with it all!!!
