What do you use to paint your frames with?
- LAWFISH
- City: CAMBRIDGE
- State: ID
I have the bed off of my truck and the whole front off of it. So I may as well paint the frame. its my 67 PW W100 short wide. I dont want it body color OR ANYTHING REAL PERFECT, ITS GOING TO BE A DRIVER AND 4X4. i WAS thinking red liner or maybe something a little bit less thick but of the same consistancy? HAS ONY ONE DONE THIS?
LAWFISH
LAWFISH
1977 Ramcharger slant 6
1950 Studebaker SHORT BED 4 SALE
1967 FAIRLANE 4 SALE
1979 DODGE EX CAB SHORT BED POWER WAGON 4 SALE
67 /63 BASTARDISED SHORT WIDE POWER WAGON 8 LUG.[/
Re: What do you use to paint your frames with?
Seeing as though you're in the land of inexpensive, plentiful, low rust Sweptlines, youLAWFISH wrote:I have the bed off of my truck and the whole front off of it. So I may as well paint the frame. its my 67 PW W100 short wide. I dont want it body color OR ANYTHING REAL PERFECT, ITS GOING TO BE A DRIVER AND 4X4. i WAS thinking red liner or maybe something a little bit less thick but of the same consistancy? HAS ONY ONE DONE THIS?
LAWFISH
might give thought to using a can of paint on Rustoleum
- 62dodgedog
I just put Gator Guard inside my CJ7 but before I sprayed that in I put some chasis cover, can't remember the name, down first just to seal it good. Got me to thinking this would look real good and cover up nicely on the frame of my "62. It brushes on easy and gives a pretty decent black shine.
'62 D100 lwb, 318, 4 speed.
'63 D100 lwb, 225, 4 speed
'65 Plymouth Valiant, 225, auto
'86 jeep CJ7
'86 jeep CJ7
- RussRoth
- City: Vancouver, WA
Hobcobble wrote: Seeing as though you're in the land of inexpensive, plentiful, low rust Sweptlines, you
That's what I used. Rusty metal red primer first and then black over that. The black does not stand up to brake fluid but the primer does. Easy to touch up though.
RR
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
- nfury8
- City: KC, MO
Another vote for Rustoleum or similar. My crew has some tractor paint on the frame
that was $20 a gallon in satin black. It has worked out great, easy to touch up and and
pretty tough.
FYI, POR-15 doesn't hold up against brake fluid either. Don't ask how I know.
pretty tough.
I'm not understanding where the brake fluid is coming from?? the master cylinder is on the firewall and all brake lines are connected before fluid is put in, and when bleeding, in 1 person with 1 man system then that goes in container, 2 man system, not even close to the frame, so whats up with you guys and brake fluid?
if you really want it to last for a long time then first strip it down all the way down to bare metal, treat your metal with this Metal ready if you follow the instructions will eat any surface rust, notice I said eat, for its gone not hidden, then once thats done you can use their frame paint, @ www.por15.com this will last for decades
try not to take a bath in brake fluid
I wonder if I'm the only one with a painted Master Cylinder, I put silicone brake fluid in 1 time 5 years ago and its still their never had any leaks whatsoever.
- PowerMan
- City: Auburn
We got our frames sandblasted and then just sprayed on John Deere Medium Gloss black (no primer).
It looks nice.
Power Man
It looks nice.
Power Man
- tinbasher
- City: Cache Creek
por-15 is tough, tough, tough.
i think it works better if you sandblast first though.
rjm
rjm
- Jims68
- City: Edgewater Park
- State: NJ
I wire brushed my frame by hand, and a drill with an attachment wire wheel. I used a $20 gallon of Rustoleum on my frame and no primer. I used a brush and painted it outside when it was nice. Still looks good. You don't see much of the frame anyway, unless you look into the fender wells, or laying on your back on the ground. Also, if your doing a driver, no sense in spending a TON of mony on POR15 either. POR15 is nice though, but expensive. IF your doing a show truck, then, I would not brush on the paint.... but do a "show" finish on it. I don't see the point of doing a show paint job on the frame if it is going to be driven though...
As for "how" brake fluid gets on the frame... loose connections, or a bad flaring job... at the junction block that mounts on the frame.
- nfury8
- City: KC, MO
The subframe on my Fury was sandblasted, treated with Metal Ready and then painted with POR.
A fitting on the combo valve, mounted on the frame rail, developed a small leak. Just a drop
here and there, took a whole season to loose enough fluid to really notice the level drop.
Ate the POR off, in a 2 foot long, 1/4" wide stripe.
I see lots of talk about POR being the end all, but some quick searching will show many cases
of the opposite, including a auto restorer magazine. That write up is available on Eastwoods site.
I have also used Eastwoods Chassis paint, which is nice, but not as tough as advertised.
Don't get me wrong, not saying POR is junk, just not all the hype would say.
After the frame on my crew was blasted I primed it with a rattle can rust converter, and then
used the tractor paint. For the cost, I am much happier with the tractor paint vs the POR.
Also, I could have had it powder coated for what it would have cost, had I painted it with POR.
POR does setup HARD, DON'T get it on any threads! I got sloppy with it on the spindles for my
crew and almost didn't get the caliper brackets on!
I just ordered a Gallon of POR15 and its under $40 with shipping ($31.75+shipping) I don't think that is too exspensive, and considering the "long term" savings? I'll be tearing into the Project 68, and that will be used on everything, and it will be a daily driver but I also want it to look nice to go out on the Weekends and "hang out" with the other Sweptline truck owners here
I've read where some restoration shops say not to use a very hard paint on frames. They recommend using a plain air dry enamel like Rustoleum or similar if you are going to drive the vehicle. The reason is that enamel stays more flexible and if a rock hits it it does not hurt, while a hard paint will chip if it's hit hard. I've use Rustoleum on all of the trucks that I've restored and it's worked out fine for me. I've also used some paint that was labeled "chassis black" that worked well.
1969 Adventurer W100
Robin....MountainMoparRobin wrote:I just ordered a Gallon of POR15 and its under $40 with shipping ($31.75+shipping) I don't think that is too exspensive, and considering the "long term" savings?
Let us know your source for $40/gal. POR-15. Their official website lists it for $143.00 FOB.
I used POR-15 on a '68 D100 frame.... did the prep work as directed.... used the metal prep
as directed..... did everything according to their instructions. I top coated using their Chassis
Coat black.... per their instructions. If this gets "knicked".... it peels off in sheets. I ended
up having to re-surface large areas of the frame and I went over them with Rustoleum primer
and top coated with Rustoleum semi-gloss black. I've heard success stories and, like in my
case, I've also heard not so good stories.
Please post the link for $40/gallon POR-15 for those who believe in it.... that's a heck of a
deal.
I just ordered it from their website www.por15.com don't know where you saw that price?
METAL-READYTM provides the best adhesion for POR-15® on any metal surface, including aluminum and shiny polished metal surfaces. Our simple process gently etches metal, creating an ideal anchor pattern for coatings such as POR-15®, while simultaneously leaving a zinc phosphate coating to insure chemical bonding of paint and steel. Avoid other preps that may leave harmful residues which prevent proper adhesion. After thoroughly degreasing your work piece, apply environmentally safe METAL-READYTM to both neutralize any rust and etch any clean bare metal. This will allow better adhesion of POR-15® or any other paint. METAL-READYTM is not caustic, corrosive, toxic or flammable.
Quart.............. $16.50
Gallon............. $31.75
Size Please select GALLON QUART
Qty
Qty
Hobblecobble where in the world did you see 143.00? I don't see that on their website http://www.por15.com/prodinfo.asp?grp=MR&dept=2
you have to click on Metal Ready to order and the information I posted came from their website, I've been ordering from them for almost 10 years and the price has been almost unchanged I don't think they have a product that is even close to $143.00 unless its a year supply?
don't know what you could have possibly done wrong but you need Metal Ready to treat the body with also, if you take it down to bare metal, it etches it, and stops rust, notice I said "stop" not cover or convert
- nfury8
- City: KC, MO
The Metal Ready surface prep is $31.75 a gallon.
The POR-15 paint is $143 a gallon - $29.95 a pint.
http://www.por15.com/prodinfo.asp?grp=1&dept=1
Robin,MountainMoparRobin wrote:Hobblecobble where in the world did you see 143.00? I don't see that on their website http://www.por15.com/prodinfo.asp?grp=MR&dept=2
You stated that you bought a gallon of POR-15, which I took to mean the actual paint on
black coating which is what I found at $143/gal.. Metal Ready, as I understand, is $31.75/gal..
I used the Metal Ready when I did my frame.... then the POR-15 black coating followed by
their Chassis Coat Black...... all their products..... all applied per their instructions. It peels
off when nicked. I did it all properly.... don't know what else I can say
- 63d100sixer
- City: Riverside
Step one...go to home depot
step two...buy 5 cans of el cheapo gloss black spray paint...its $.99 a can...
not a real good shot, but it looks great, best of all, since its gonna be under the bed, it doesnt have to look great
step three....spray away, just clean really good
1968 D200 318 727
1972 D100 360 4 speed
1973 d100 318 727
1973 W100 440 727
1968 D200 318 727
1973 d100 318 727
1973 W100 440 727
Yeah that would suck, to have it peel off, I used the frame paint also after metal ready on the 440 and its still their.
but the paint isn't as important, I think any of the paints should do fine.
2 ways of dealing with rust
1. kill it
2. smother it
if it doesn't get moisture or oxygen it can't spread
1. kill it
2. smother it
Kill it.... smother it.... grind it.... sand it..... wire brush it..... just keepMountainMoparRobin wrote:Yeah that would suck, to have it peel off, I used the frame paint also after metal ready on the 440 and its still their.
1. kill it
2. smother it
in mind the words of Neil Young..... "Rust Never Sleeps"
I've had great luck with Rustoleum Rusty Metal Primer and their Semi-Gloss
Black..... brush it on and forget about it.
