metal for bed????
metal for bed????
does anyone know if anyone makes the ribbed metal for beds in sheets that you can buy and cut to fit? my bed is in good shape but the ribbed bottom is rusted out in a few places and is very bent up
Re: metal for bed????
Try:juddoats wrote:does anyone know if anyone makes the ribbed metal for beds in sheets that you can buy and cut to fit? my bed is in good shape but the ribbed bottom is rusted out in a few places and is very bent up
http://www.jcwhitney.com
http://www.millsupply.com
You'll have to ask to see if the ribs are the same width and
distance apart.
i called jc whitney and they didtn have it... mills supply has the metal for 72 and up....does anyone know if there is a difference in the rib pattern?
I have a bed that i'm willing to hack up if needed. I believe the floor is in pretty good shape. The back corners are jacked up, I'm out in the Dallas, Tx area.
http://www.Sweptline.ORG
1965 Dodge SWB D100 (Utiline)
1970 Dodge LWB D100 (Dude)
what would you want for the bottom of your bed? is the bottom of the bed bent up or are you saying the back of the bed is bent up? you dont happen to have a good tail gate do you? mine is pretty bad
- Oldguy
- City: Reno
- State: NV
Finally got a chance to measure the ribs. The 77 ribs are 1 5/8ths, both rib and flat, with a 1/4" rise. Both the 66 and the 69's have 2" ribs and flats with 1/8th rise. Hope this helps. Mike
Thanks...i knew mine but didnt know the newer models rib measurment
I called millsupply and they said they only had specialized panels for trucks other than Dodge. (80's Chebbies and Phords)
I wish someone knew where they were being made and get just like a full sheet before it is cut or anything and then ue it.
The ribs wouldn't be exactly original but they would look very nice.
- HEtkind
- City: Johnson City, Tennessee
1/4" diamond plate...
Howard
62 Dodge D100 Town Wagon
62 Dodge M-37
68 Dodge D100 Utiline
2007 Dodge Ram 1500ST
62 Dodge M-37
Shoot me an e-mail and we'll talk about the bed floors i have.
