real quick lowering question
383mrollg
Post by 383mrollg »
hey guys thinking about lowering the front while its parked for a few months to see if i like it.
question is can i leave the shock mounts in the same place ( above the axle but under the leafs ) and just swap the leafs under the axle with longer u bolts?
also will this reduce strength for the shock mounts because there wouldnt be springs resting on it.
chris
1970 D100, Built 383,727,3.91 SureGrip.
DavidWymore
City: El Centro (of nowhere)
Re: real quick lowering question
Post by DavidWymore »
You have to have the pin locate the axle on the springs...not just the Ubolts clamping them on. I don't think the flip will affect shock mounting point strength, but the shock might bottom out=break something if the axle goes up on top of the springs and the shock goes with it.
Note center bolt.
I remember seeing the lowering job on that wild blue and red truck with the bling wheels and thinking YIKES!
oklamopar
City: Midwest City OK
Post by oklamopar »
viewtopic.php?f=20&t=15894
alot of good stuff
Later,
Skip
So here's to you...
slick
City: Tucson/AZ
Post by slick »
Chris, let me find the brackets that I made for the front. I will send them to you to see if you can lower that beast. Like I said before they are not the greatest thing, but will let you see if you like it lowered. Cantspels set up is pretty sweet I would try to replicate that..
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
383mrollg
Post by 383mrollg »
hey thanks man i appreciate it , just email me if ya ever find em, i might just go ride down there on the ol bike to get em.. give me an excuse to go out for a ride.
chris
slick
City: Tucson/AZ
Post by slick »
Chris, I found the brackets if you want them...
1961 Dodge D100
1964 Dodge Polara
sweatybetty
City: s.w.
Post by sweatybetty »
power wagon springs are reverse arched and would be a bolt in
