Well, finally home after two weeks on the road...and all the parts I ordered have come in:
Now I need to run to town and get decent weatherstrip adhesive, and remove the old stuff. What do folks like best? Contact cement is kind of cheesy.
front wheel bearings and seals: installed
rear rubber brake hose: installed
new plastic hub caps: installed
new ignition switch and lock cylinder: installed
cat wiskers: installed
door weatherstripping: in process
commnets:
the Dante cat wiskers went right in with the windows in place
ignition switch and lock cylinder, under five minutes
wheel bearings and seals, two hours inlcuding reswadging left front drum and tapping in new races, red citco mystic jt grease used, no more bearing whine
used new plastic wheel covers since I am having trouble locating decent dog dish style hub caps
Howard
favorite weatherstip adhesive?
- HEtkind
- City: Johnson City, Tennessee
Howard
62 Dodge D100 Town Wagon
62 Dodge M-37
68 Dodge D100 Utiline
2007 Dodge Ram 1500ST
62 Dodge M-37
- City: LaA
Re: favorite weatherstip adhesive?
I used 3M weatherstrip cement, the one I used was yellow but I understand it also comes in black now.
If you use it only do a few feet of weatherstrip at a time it really works at sticks very good, follow the directions and make sure its lined up when to stick it down.
Be nice to have a friend help hold the long end when doing the one around the doors.
Oh rubbers gloves do ask my wife about that though
- demulsion
- City: Bremerton
That was discussed recently here:
viewtopic.php?f=5&t=13998&start=0&st=0& ... atherstrip
A word of warning, the 3M "yellow" Jims68 cautions against, comes in a black tube! I didn't realize until I got home, so I figured it can't be that bad, and I'd just try it. I did one door with it... It was so bad I didn't bother doing the other side. It's been a few months now, and the yellow stuff is already coming undone in at least 3 places. Hope that helps.
- City: LaA
Okay there are two differnt types of the yellow 08001 and 08002 I used the 08001 in the RED tube it works great and holds forever
http://solutions.3m.com/wps/portal/3M/e ... TWTJQPBBgl
- OleRed66
- City: North
- State: UT
tom-adc wrote:Okay there are two differnt types of the yellow 08001 and 08002 I used the 08001 in the RED tube it works great and holds forever
I have the same stuff and it works just fine for me too!
1966 Dodge D100 - Ole Red
1985 Honda Magna - Maggie
- demulsion
- City: Bremerton
Thanks for straightening me out, guys. I'll have to look for some of that now.
- OleRed66
- City: North
- State: UT
just don't drip, or get it in your arm hair
